1 - 15 of 15 Posts
hey i just put my exhaust on this weekend and it sounds good but from the inside when you give it gas you can hear a clicking of some sort. As you give it more throttle the ticking speeds up. any ideas of what it is?
MM's official Chevy guy
a leak
well where does it sound like the clicking is coming from? you could seafoam it, or just pop the hood and rev it manually. you should be able to tell if it is in the headers region if it sounds like the noise is happening right there when you rev it manually - if it isn't from right there check where 95stangvert said to look
its coming from the passenger header how do you seafoam it?
get the car up to running temp than you put 1/3 of the can of seafoam in the gas tank, 1/3 in the oil, and 1/3 in the vacuum hose. and then from there i dont know wut to do lol. so someone else can finish the story for me
if u know it is coming from the pasenager header, then go adead and tighten it down so it dosent leak
tq speks r 23-26 ftlb's
can i do the old soapy water trick and see exactly where it is coming from
Discussion Starter · #12 ·
well how do i find out which block it is
i dont understand the question, but to find the leak, the seafoam will be your best bet. the soapy water would probly work but i dont like the idea of water being inside your headers and stuff, rust is really bad if its on the inside
Discussion Starter · #15 ·
yeah i put new gaskets on and locking bolts but looks like i am going to have to retighten them thanks guys
1 - 15 of 15 Posts
