1 - 13 of 13 Posts
if you can weld then you can do them...weld well. and do wiring
not that i know of, there is alot of space under there, i would put them right after the x pipe so that it can still do its job of equalizing manifold pressure
if you can do the wiring, i would say about 100-150
N/A 4v Guru
Do you have an aftermarket cat-back? If not, and you are gonna have a shop put the cut outs in, you could get a nice cat back for what it will cost to buy E-cutouts and have them installed. Just my .02
N/A 4v Guru
You can put them wherever you want, after the X will be the best place. Do you have an aftermarket mid pipe too? You do know you are not going to gain anything but noise with cutouts right?
N/A 4v Guru
If the mid pipe is the stock one (2 1/4" ugly H pipe with 4 cats) then get an O/R X or O/R H. That will give you a great sound improvement and a nice boost in power, all for less then you will spend on E-cutouts and having them installed.
1 - 13 of 13 Posts
