1 - 12 of 12 Posts
ok i was planning on getting some 03 machined cobra wheels, if I get the 10.5" rear will I have a problem with the rear exit exhaust? I notice alot of dd guys dumping their exhaust. btw, i'll be running 315 rear tires if that helps.
i dont beleive youll have a problem with the exhaust at all
You won't have a problem with it. I had some 17X10.5 Bullitts with 315s on mine. Never had a problem with any rubbing. I now have 18X10 FR500s with 295s in the back and still have plenty of exhaust clearance.
The Mean Green
No problems man
no problems with mine 10.5 dd with 315 eagle f1s I almost went 335 so you will have no problem. and if for some odd reason you do just buy a spacer
i got what you want they fit
17x10.5 / 315/35/17 nittos
they should clear the top irs bolt too.they only hit if you got a 315 tire with a rim saver made into the tire, nitto 315 dont have the rim saver.
i got solid axle. btw.
1 - 12 of 12 Posts
