1 - 20 of 24 Posts
My exhost pops and I loose power in 4th gear once I hit 130, it's fine in every other gear. My other problem is I'm loosing clutch pressure when I hold the clutch down to long. And it started after I replaced the clutch, flywheel, and hydrolic throw out berring. What could cause this to happen
^that makes a little more sense!! i was wondering this myself, 4th gear at 130!! LOL
Tini Tini Bo Bini
you guys have apparently never opened up with 3.31s. its very doable
no way, even with 3:31s, should the OP be sitting at 3500 rpm @ 130mph...im at around 6200rpm with effectively 3:90s because of my tire size...no way in hell it is that different.
he would be able to go over 150mph in 4th if that were true..
Tini Tini Bo Bini
maybe not the 3500rpm part but 130 in 4th is very doable. ive buried it in 4th with 3.31s.
1 - 20 of 24 Posts
