1 - 6 of 6 Posts
Man i'm so sick of this damn fan not coming on.
I've put in brand new coolant sending unit sensor, coolant temp sensor, new fan, and even bought a damn new CCRM from ford for 200 bucks.
I check the ground going into the fan it shows me a light on testor, but when i check the low speed + high speed... nothing.
Really pissing me off. Only other thing i can think of is the PCM is bad mayb? idk
Does the fan run when you engage the A/C? I believe that the cooling fan should run as long as the A/C compressor is engaged. Other than that and everything you have already done, it may be a trip to Ford... :dunno
There should be a relay and fuse for the cooling fan...I presume you have verified those are OK? Pull the plug on the fan while the motor is running with the A/C turned on and stick the connector with a test light to see if there is power at the plug. Outside of that, you may have a wiring or ECU issue.
1 - 6 of 6 Posts
