1 - 7 of 7 Posts
Alright I got my swap done tonight and I went to crank her over and nothing. Fuel pump runs, relays and everything click but the thift light is flashing like a sonofbitch. I went back and checked and rechecked all my connections and all that good stuff. Now, I have tuned it with the Sniper Special Forces. Could this be an issue?? I also deleted my EGR. So What could be causing this?? I'm pretty sure Im f**ked. If so, bye bye mustang
Discussion Starter · #2 ·
Got that problem solved. now onto the part that makes me look really dumb. i put in a new oil pump and all that good stuff. How do I pre-oil my engine. Everything is put together and she starts but no oil pressure. And I'm too scared to start her up again, I dont want a new motor yet!!!! Help
Proud American
it will prime almost instantly. If you used assembly lube, it will keep it lubed up until oil can get in there. And dont go by the pressure gauge in the dash, gt an aftermarket one.
+1
Ok thanks guys. So just start her up and let her run and It'll all be good??
1 - 7 of 7 Posts
