1 - 2 of 2 Posts
i have a 1989 ford mustang and i cant find the grommet inn the firewall to put mi amp power wires through were is the grommot??
If it is an automatic car, it will be on the driver's side where the clutch cable goes. If it is a stick, then you might want to use the large factory grommet on the driver's side where the main harness goes through. Make a SMALL slit in the rubber (don't get too crazy, you don't want to cut any wires in there) and push you amp wire through.
1 - 2 of 2 Posts
