1 - 2 of 2 Posts
So I started a PI swap on my stang on sunday. Pulling the engine was easier than I thought, the only pain was the top starter bolt as always, and that bolt on the power steering pump behind the line with the bracket on it. Anyway, I have the engine on a stand and I found a cracked weld on the drivers side header collector flange. It should be able to be repaired right? I know a couple of MK's on base that can weld very good.
[/IMG]
Rollin' 18/ pushin' 2
Looks repairable, but if it has already been repaired once and has cracked again I would grind off the old weld first just to make sure you are getting it right this time.
1 - 2 of 2 Posts
