1 - 15 of 15 Posts
I've got an exhaust manifold leak on my mach 1 (55k mi) with long tube headers. I know the gasket is blow (got copper gaskets because I heard they were the best?) and I know for sure the the "header" bolts that are on there now are loose. So my questions are: what is the best way to go about fixing this (lifting the motor out or dropping it?), should I use studs or bolts on the manifold? and also is there anything else I should do down there while I have the motor out?
Sent from my DROID RAZR using AutoGuide.Com Free App
If they are just loose, it MIGHT be possible to tighten them up with the motor still in. If not, I would just support the motor and drop the K member out of the way, fix it, then put the K member back in.
I reached in and tighten them down as much as I could (they were really loose) but they still leak just as bad. The gasket is blown I think. Dropping the k member sounds easier; we might have to try that. Thanks
Dropping the K isn't a bad job at all. Maybe 4 hours for someone that has never done it. Only **** thing is bleeding the brakes after you put all back.
Bleeding the brakes? I'm a complete newb so I'm not sure what the is lol. My cousin and I are going to try and do this job. He has been around mechanics all his life but is not actually a mechanic. For me to try to do this on my own would be to sentence my car to death lol
You shouldn't have to bleed the brakes bro dawg
Use the stock studs where possible.
This is what I was told also but then I snapped the forward most bolt on the passenger side and said, "never again".......my 96 with ARH longtubes now has the Stage 8 bolts.
By the way, buy the Stage 8 bolts in the Stage 8 package, not the FRPP package----you're paying extra for the FRPP name. Compare the prices on Summit Racing and you'll see what I mean.
Discussion Starter #12
Is there anyway you can give me the link to buy stage 8 bolts. I can't seem to find them. Haha
Thanks for the info you guys. It really does help!
11.5:1 or GTFO
Definatley get the Stage 8 bolts. I've heard people say just buy the FRPP ones but like stated above, they are prone to break quite often.
Discussion Starter #15
Thanks for your input everyone! :)
One more question though.. what does everyone think about studs? Any input?
I just want something that will work so I don't have to go into this again lol
1 - 15 of 15 Posts
