I've got a 2000 V6 mustang that was in a flood. Water got to the bottom of the dash. I've replaced the starter, battery, CCRM, and the ECM. The car will turn over fine, but will not start. I've check no spark or fuel. You put the key in turn it to the run position and the only lights that light up on the dash are the brake in the theft light. If you wait for about 3 to 5 minutes other dash lights come on and the gauges do a full sweep. I've checked every ground wire I can find and still nothing. I've hooked up a Snap-On scanner tool to the OBD2 and it won't read until the gauges through full sweep and then it says no communication. Out of ideas Help anyone have any ideas
