1 - 5 of 5 Posts
I Poop Entirely Way Too Much
Are the flywheel bolts reusable?
do you like your legs? yes you can re-use them, but no you shouldn't if that makes sense.
The shop manual does not specify that they cannot be reused, and if there were such a specific prohibition it would...
was asking cuz I recently read that heads bolts are good for 6 uses. And I bought new ones when I re did the engine the first time.
Flywheel bolts are NOT TTY. Ive checked and check and checked, and they are not. Ive reused mine twice.
As far as head bolts, re-using them, I really dont recomend that. Just to be safe, spend $30 on brand new ones at ModularHeadshop or MMR. Same with all the block bolts.
1 - 5 of 5 Posts
