should i replace my flywheel when i do my clutch or just get it machined,if i do replace what should i get aluminum or another steel one?
thats the brand i was considering but undecided on aluminum or steel.Haa that ****** is crazy azz hell!
I would replace it, y not? A good flywheel like fidanza is a step up from stock and u got the tranny pulled out anyway mind as well
how do you like the aluminum flywheel?when I replaced my clutch with the stage 2, I went ahead and changed the flywheel to a spec aluminum one. But I say if yours is fine and your not going to do much to the car might as well just keep what you have
