1 - 15 of 15 Posts
if its just a bulb maybe $3. lol. if its the assembly i think you should probably be able to get one used at a junk yard for no more than $20
just crawl under there and when you see the bulb turn it either left or right i forget and itll pop out, then just unplug it and put the new one in.
yeah.. i had the same thing happen to me last summer.. the bulb just freaking popped and then the hydrogen hit the oxygen and my freakin fog light housing filled partially with water :mad: it should be simple if you get a bulb, though.. if you remove the housing, though, be careful cuz there is this little spring that tries to sneak off
1 - 15 of 15 Posts
