1 - 12 of 12 Posts
anyone have the wireing diagram for an 86 gt fog lights,, some ass cut them off at the switch and i have no idea what goes where.
Thanks
you might google it or it might be in a haynes
Sure, here goes.
Take a positive switched wire from the fuse box up to the fog light switch. The original position for the fog light power is from fuse 15. From the other side of the switch run a wire through the firewall to a relay as the switching wire. Then run a ground wire to the relay, a battery wire to the relay, and the forth wire from the relay goes to the fog lights as the positive wire. Run the negative wire from the fog lights directly to a chasis ground.
thanks for the help.. just need to find the relay now,,,lol
they didn't come with one from the factory, just go to autozone or any other auto parts store and get a standard 4 post 30 amp relay.
1 - 12 of 12 Posts
