1 - 10 of 10 Posts
Any idea why my fogs wont turn on as of a couple minutes ago? Fuse seems to be fine. All of my indicator lights came on while driving slowly through a parking lot. Just the actual 6k fog lights wont work. Everything else is working fine. I installed them a few months ago and have never had the slightest issue. Any ideas guys?
switch maybe bad,did you check to make sure the ballast is getting power,i assume you have hid kit since u said 6k
What do you mean when you say switch? No, the high beams aren't on.
the switch below your arm rest,that turns the fog lights on,it maybe bad and it really sounds like it is consider that both light stopped working
You mean the actual know that I pull to turn on the fogs and head lights?
on the 99-2000 the switch is on the center console next to the coin holder
1 - 10 of 10 Posts
