It's a sad day in South Florida. There has been talk about budget cuts and layoffs at the Fire Dept I work at, so financially I'm not 100% if I can keep my pride and joy. So, I'm testing the waters to see if there would be anyone truly interested in this awesome machine. The stang was built by the crew at Blow-By Racing in Boca Raton, Florida.
My name is John Zeilinga
The stang is located here in Boca Raton
I'm asking $22,000
BBR 2V SOHC 284cid Short block
* 8.8:1 Compression Ratio
* Kellogg Crank
* Diamond Pistons
* Manley Rods
BBR 2V CNC Ported PI Race Heads
* +1mm Manley Valves
* Comp. Cams High Load Valve Springs
* Custom Grind Comp 2V Cams
* Cloyes Adj. Cam Gears
Kenne Bell 2.8H Twin Screw Supercharger
AFCO Heat Exchanger
JLT Carbon Fiber High Boost Cold Air Intake
SCT BA 3000 Meter
3.25" Blower Pulley
Innovators West 10% over drive crank pulley
Meziere Electric Water Pump
Mellings High Volume Oil Pump
Moroso Reservoirs
Moroso NHRA Legal Battery Relocation Kit
BBR Fuel System Upgrade Kit
* BBR Billet Fuel Rails
* 60# Injectors
* Fore / BBR Fuel System- Triple Pump Hat w/ (3) Ford GT Super Car Pumps
* Fore 3-1 Fuel Block
* -8 Fuel Lines
* Numerous Fittings and Crossover lines
Moroso Street/Strip Oil Pan
SHM 1 3/4" Longtubes
3" Collectors
3" Moroso Race Mufflers
TKO 600 Transmission
Steeda Tri-Ax Shifter
Lakewood SFI Approved Modular Bellhousing
McLeod Twin Disk Clutch system
Fidanza Aluminum Flywheel
33 spline axles
C-clip eliminators
Spool
3.73 gears
Team Z Motorsports tubular k-member, a-arms & coilover kit
Steeda upper & lower control arms
Team Z Motorsports Anti-Roll Bar
10 point moly cage by: Tig Vision Welding
Team Z Motorsports Aluminum Drag Wing
SCT X3 Tuner w/ BBR Custom Tune
Bogart D-10 Drag Wheels
* 15x3.5" Fronts w/ DOT M/T Sportsman Tires
* 15x10" Rears w/ 325/50-15 M/T Drag Radials
Kaenen 5.5" Cobra R Hood
Ford OEM 99/01 Cobra Front Bumper
Ford OEM V6 Rear Bumper
Corbeau Legacy Adjustable Racing Seats
UPR Driver & Passenger Side Airbag Delete Kit
American Muscle Smoked Headlights w/ Clear Side Markers
SOS Radio Delete / Gauge & 12V Switch Panel
HP: 616
TQ: 524
15psi 93 Octane
Room for a lot more!!!
I'm asking $22,000
* Kellogg Crank
* Diamond Pistons
* Manley Rods
AFCO Heat Exchanger
SCT BA 3000 Meter
3.25" Blower Pulley
Moroso Reservoirs
* 60# Injectors
* -8 Fuel Lines
3" Collectors
33 spline axles
C-clip eliminators
Spool
3.73 gears
HP: 616
TQ: 524
15psi 93 Octane
