1 - 20 of 22 Posts
TFS r-series heads TFS-52400003-CNC used for one summer with under 1000 street miles - $1100
TFS 1.7 roller rockers TFS-51400521 used for one summer with under 1000 street miles - $175
Ford Racing aluminum drive shaft used for one summer with under 1000 street miles - $175
MSD 8584 351W distributor only 4 dyno pull and 4 passes. - $175
[email protected]
the driveshaft came from a foxbody, right?
Trades are welcome. Here is a list of some parts I need:
- Tubular K-member and control arms
- manual rack
- aluminum street radiator for fox body Mustang
- Flex-a-Lite Black Magic fan for fox body Mustang
- Comp Cams 838-16 solid roller lifters
- Crane Gold, Trick Flow or equivalent 1.6 ratio roller rockers
- Edelbrock Victor EFI intake for 351W part number EDL-3887 or just the upper or lower is fine too. I'll take what I can get. A Victor 5.0 upper will work too.
- 351 EFI distributor MSD part #8452
- 42lb to 60lb injectors
- 87-93 Mustang adjustable fuel pressure regulator
- 90mm or larger throttle body
- 90mm or larger mass air meter calibrated for 42lb or larger injectors
- Electric water pump (preferably a Meziere but I will consider other pumps)
- Eaton 31 spline locker
- 31 spline stock length fox body axles with C-clip eliminators (Strange or Mark Williams preferably)
TT mfn T
is the distributer for efi car or carb if its carb i will take it mech or vac advance
Its for a carb and it has a locked out mechanical advance as well as a bronze distributor gear.
Discussion Starter · #12 ·
Pending sale on heads and driveshaft
ill take the driveshaft :D
do you except money orders?
Discussion Starter · #14 ·
I did respond to your PM. Sorry about not responding here sooner. I missed the post somehow.
Pending sale on driveshaft. I'll post for sure in the next day or two if it is sold or still available.
Discussion Starter · #15 ·
TFS R heads are sold!
Discussion Starter · #17 ·
Driveshaft still available. Deal fell thru. I know a bunch of you PM'd me about the shaft but I'm making a post here instead of sending 20 pms out lettin you guys know its still available. Shipping will be $35 in the lower 48 states. Now I just need to find a box to put it in....
How about the deal on that rear end , has it fell thru or still in the works?
Discussion Starter · #20 ·
I have to go look at it, hopefully this weekend.
1 - 20 of 22 Posts
