1 - 4 of 4 Posts
Do any of you guys run Ford C-springs? I was wondering if the ride is horrible..
C-Springs here...ride is like a sports car! Handles good, bumps are a bit more harsh but not like a Lincoln with blown air bags!!!:D
Bullitt/Mach 1 springs are quite similar, and I've had those on my Fox and obviously our Bullitt. They're stiffer than stock, but the improvement in handling and the "tighter" overall feel of the car is worth any diminished ride quality. Honestly though, the ride quality, imo, won't be significantly worse if you have quality matching dampers... which is something you should get when bumping up the spring rate as much as you are.
1 - 4 of 4 Posts
