1 - 20 of 22 Posts
apple valley ford will sell parts to mm members at 10% over cost does not include shipping this also includes ford lincoln mercury parts. special pricing on engines and tranmsions.
we sell ford parts, ford racing, vortech, edelbrock superchagers.
Discussion Starter · #2 ·
avfracing has some ford racing parts that we want to sell cheap,
we have 4 of the m-5230-5gt muffler set for 430.00 plus freight 05-2010
we have 5 of the m-5230-s muffler set for 470.00 plus freight 05-2010
we have 2 of the m-9603-svt07 with ford tuner for 670.00 plus freight
fits 07-09 gt500
for the 5.0l/5.8l mustangs we have the ford racing old style z-head kit m-6049-z304a2. it comes with 2 of the m-6049-z304a heads and a set of the m-6564-k351 rocker arms. price is 1100.00 plus shipping.
Discussion Starter · #4 · (Edited)
we have a set of ford racing GT cylinder heads, the camshafts are damaged (customer dry started the engine) will need new cams, ford racing offers kit, and 2 new bare heads. they are complete heads with the bad cams still with them. need to sell if intrested make offer. we can work out pricing for new cams and bare heads also. any questions please feel free to email ([email protected]) or call 952-431-1414 ask for steve.
we also have alot of over stock parts that need to sell, ford racing, slp long tubes for the gt500. bbk long tubes for the 05-09 4.6l 3v. will sell cheap, need to get ready for next year's new parts coming out.
what parts do you guys have for the 99-04 style GT's. you got anything your trying to get rid of cheap?
Discussion Starter · #8 · (Edited)
new pricing on this block
$1750.00 no freight charge
M-6010-SST50 5.0L ALUMINUM "CAMMER" CYLINDER BLOCK - STREET / STRIP APPLICATIONS
· Big bore 4.6L aluminum block with cast iron liners
· 94mm (3.70") cylinder bore size. Stock cylinder bore size 90.2mm (3.552")
· 227mm (8.9370") deck height (same as 4.6L)
· Produces 5.0L displacement when used with a 4.6L stock stroke crankshaft, stock length connecting rods and custom 94mm-diameter pistons
· Cross bolted main bearing caps
· Machined for heater return fitting. (heater return fitting included)
· Thermostat bypass drilled in LH deck face
· Compatible with 2V/3V/4V cylinder heads
· Reduced valley depth limits intake manifold/supercharger applications
· Will accept production 3V production intake or 3V Whipple supercharger
· Will not accept 2003-2004 Cobra production supercharger
· Will not accept 1996-2001 Cobra or 2003-2004 Mach 1 production intake manifold
· Will not accept 1996-2004 4.L 2V production intake manifold
· Requires water pump YR3Z-8501-AB/Motorcraft PW-402 long 87mm (3.425) pump or YW7Z-8501-BB/Motorcraft PW-409 short 65mm (2.559) pump.
· Same block that is used in the 5.0L "Cammer" crate engine.
· Replacement sleeve M-6055-B
· Head changing kit M-6067-3V50 recommended for 3V
2010 Mustang Cobra Jet Optional 475 HP Engine Upgrade $20,100.00$
Compression 9.6:1
Includes:
Ford GT Aluminum Block M-6010-GTWS
Unique Cobra Jet Signature Build Plate from Romeo Engine Plant Niche Engine Assembly Line
Ford GT Aluminum Heads M-6049/99-GT and Camshafts
Ford Racing Whipple 4.0L Twin Screw Supercharger with 4" pulley
Aeromotive Fuel Rail System
80 lb/hr injectors M-9593-LU80
Mahle flat top forged pistons
Manley Rods with ARP 2000 bolts
SFI approved damper M-6316-CJ
Single Blade Throttle Body
A/C/Heat Power Steering pulley Delete
Fuel rail spacers M-8510-M2L
Flywheel not included
Long tube headers M-9430-CJ recommended
Discussion Starter · #11 · (Edited)
WE HAVE A SET OF M-6049-Z304A2 CYLINDERS HEADS IN STOCK NEED TO SELL
$1000.00
This kit contains 2 high flow M-6049-Z304A cylinder heads and a set of M-6564-K351 roller rockers
these heads were installed but never ran customer tryed to install on a stock 5.0. the vales are to big for stock pistons. sold
Discussion Starter · #13 ·
we have two magnaflow exhaust systems in stock. they are
1 #16615, V8 4.6L, 5.4L Standard Cab, Short Bed
SC/SB, 5 x 8 x 18 in. Muffler, 3 in./2.5 in. Tubing, 3.5 in. Slash Tip; DUAL SPLIT REAR EXIT $415.00$ fits 04-08 new style f150 plus freight
1 #15749, V8 4.6L Extended Cab Pickup, GAS, 78.0 Bed Length
5 x 8 x 18 in. Muffler, 2.5 in. Tubing, 3.5 in. Tip; DUAL SPLIT REAR EXIT
fits 97-03 f150 $415.00$ plus freight
Discussion Starter · #14 · (Edited)
boss 302 short block kit
all this for only $1700.00$
The new BOSS 302 Shortblock kit features quality engine components at a very competitive price. This kit utilizes forged pistons, forged connecting rods and a steel crankshaft wrapped in the BOSS 302 block. The unassembled kit is an excellent value and a great start for any performance 302 engine build.
BOSS 302 Shortblock Kit Includes:
Mahle® forged Aluminum Pistons with ring set
Eagle 4340 forged chromoly 6-bolt crank
Eagle 4130 forged steel I-beam connecting rods
Built with all new parts: Photo and specs may vary
Engine bearings not included
Includes: BOSS 4-bolt main block M-6010-BOSS302
BOSS block features:
Splayed 4-bolt main on 2, 3, 4, main caps, 2-bolt main on first and fifth main caps
Main bearing bores finished to low limit
Finished lifter bores
Machined to accept factory roller lifter guides and lifter guide retainer
Revised oiling and cooling system passageways
Siamese bore with drilled coolant crossover holes
Increased bulkhead material
Threaded core and galley plugs
1 piece rear main seal
Tini Tini Bo Bini
i put my frpp thread in the wrong section, so it got deleted but the prices i posted are still good. the frpp 3.73 & 4.10 gears are 130.00,
is this price still good?
PM on the price of FRPP Lowering Springs/Shocks&Struts please
I would like to know this info as well.
1 - 20 of 22 Posts
