We are proud to be offering Blueprint Engines they are a great value and come with a great warranty backed by Blueprint 30 month/ 30,000mile warranty! What a deal!
Keep an eye out we will be creating newly priced engine packages on our site!
The Following is included in the BP306 Engine package.
http://fortesparts.com/index.php/product/blue-print-engines-306/
306 Blueprint block
50 OZ balancer
Mini starter SFB
Coil & bracket
302 ignition Kit
M12259 M301 black 9MM wire set
Autolite 3924 Spark Plugs
Breakin Oil Roller Cam
WIX 51515 Long Ford
Ford Fits Block
302 Stealth Intake Manifold
Intake Gaskets, Bolts & Studs
Quick Fuel Slayer 600 CFM VS
Fuel Pump SB Ford
Small Block Ford Steel & Filter
Ford 90 Degree H2O Outlet
Thermostat, Gasket, Bypass hose and clamps
Water pump
100 amp Alternator, Bracket & pulleys
10 Spline Clutch Kit & Flywheel
Fork 5.0 Mustang
Flywheel, Clutch bolts & Pilot
Bellhousing Kit
Cobra air cleaner kit
Cobra valve covers
Tremec T-5 Transmission
Machine Tail housing Boss N/C
Assembled to turn-key
Dyno Breakin and video
Fortes Parts Connection
40 Pearl st,
Framingham, MA
508-875-1600
Follow Us on Twitter:
https://twitter.com/FortesParts
Follow us on Instagram:
https://www.instagram.com/fortespartsconnection/
Check out our inventory:
http://www.fortesparts.com/
Youtube Channel:
https://www.youtube.com/user/fortesparts
Sign up for our newsletter:
http://fortesparts.com/#newsletter
If we have sold you a part or built you an engine let us know how we did, drop a comment or send us a message!
We love to hear from you!
306 Blueprint block
50 OZ balancer
Mini starter SFB
Coil & bracket
302 ignition Kit
WIX 51515 Long Ford
Ford Fits Block
Fuel Pump SB Ford
Water pump
Fork 5.0 Mustang
Bellhousing Kit
Cobra valve covers
40 Pearl st,
Framingham, MA
508-875-1600
Youtube Channel:
