1 - 4 of 4 Posts
Found this and thought it could help someone. Info posted by MMR.
(MMR 4.7 900 Hp Build) 90mm 5.0 TB on mod 4.6?? - Ford Mustang Forums : Corral.net Mustang Forum
Also for those interested in using the 87-93 90mm on the 96+ vehicles it can be done and the ECU is not a problem, obviously you must have the 90mm flange on whichever plenum you plan to use, along with a 87-93 Throttle cable and MMR cable bracket, it will require the 87-93 TPS but the connectors must be cut off and the wires must be attached per below.
87-93 TPS ------- 96+ Harness
Orange goes to Brwn/white
Green goes to Grey/White
Black goes to grey/red
Here is a pic of a 90mm on a edelbrock with MMR elbow:
1 - 4 of 4 Posts
