1 - 20 of 73 Posts
ok so here is the latest update,
baseline stock dyno 191hp 253 trq
bolt ons 213hp 268 trq
tonight, heads/intake/tb/turbo
1st pull 440hp 620trq
2nd pull 504hp 647trq 17lbs of boost (omg! im so happy she held together)
my 38mm wastegate is not big enough, going to swap for a tial 44mm
3rd pull 520hp, had to cut her off early due to drop of fuel pressure...
tuner was letting off at 6k he said she wanted more :) (no need)
CAR IS A MONSTER, i did not expect so much power and torque, crazy....where are some z06's lol
ill post up dyno sheet soon, gotta take a pic of it,
driving on hwy she spiked to 20lbs of boost and HELD up! crazy
but im going to get a 10lb wastegate spring, cuz i do not want to break anything
absolute madness!
stock bottom end, stock block, stock cam, 93 pump gas
Dude, you've prob already put a crack smewhere in your block from doing that more than once. Keep it to the first pulls numbers and you will be fine, but 20lbs, no no.
kits a piece of **** if it keeps creepin boost that bad dude, did you get it tuned with no waste gate spring? luzlz
Resident Know-it-all
Wow! 20 psi? Like has been mentioned, that's a ticking time bomb. Go with the larger waste gate and put a smaller spring and get it retuned. You'll be able to enjoy it a lot longer.
great numbers....just be careful, I'm sure you have a lot of money in her, id hate for her to self destruct
^^ How do you blow off plug wires ?
Come at me bro
lol, they might FALL off, but I doubt they are BLOWING off.
just squeeze them a little with some pliers.
If my **** gets on the dyno and touches 17 its not doing another pull derp
Powered by LSx tears
I don't know about hollow spark plugs, but I just towed my truck home because the POS showed me how to launch a spark plug out of the hole. Fuggin POS modular motors!
Come at me bro
lmao, why didn't she just sit down?
would have been epic if she got so scared that she farted, and shot a fire ball in her friends face
LOL! You too eh? Just had my truck towed home too. Died going down the road and I learned that 3 ton trucks that use the power steering pump for steering AND hydraulic brakes are kinda scary in traffic when you lose both.
How the **** did you pop a plug all the way out of it's threads BTW?
Discussion Starter #19
I meant the plug wire came off the spark plug... soo founds some issues one blew a hose clamp on intercooler piping. Had a vacuum leak car would fall on her face when entering boost. Two my oil feed line is leaking..... three driving in four hours of trafficin ny today i fried the clutch cable on an off ramp amd was stranded for an hour till a nice guy with his excursion towed me to my friends house....just took cable out new one going in tomorrow
Like snatch said. The POS modulars blow plugs out, because they literally have 3 threads that hold the plug in the head. I was sitting at a stoplight, and when it turned green, I touched the gas and BOOM! It blew the plug out. So not only does it rip the threads out of the head, but it ruins a $100 coil pack too. It's a PITA to work on too. I hate modulars.
1 - 20 of 73 Posts
