1 - 20 of 23 Posts
taken and summarized from fordracing.com article
Under the hood:
4.6-liter, 4V aluminum block, bored to 5.0L
4-valve cylinder heads with radical cam profiles
Variable geometry magnesium intake manifold
Dual 80mm mass air sensors
Dual 70 mm throttle bodies
High-flow stainless steel tubular headers
Powertrain:
Dual-disc Valeo clutch
Tremec T56 six-speed transmission
Metal matrix composite drive shaft
Torsen TR2 limited slip differential
8.8 rear end, 4.10 gears
Numbers:
415 hp @ 6800 rpm
4.6 60mph time
12.7 quarter mile
Top speed ~175 mph
street tires
Exterior:
carbon-fiber:
hood
front fascia
front fenders
rocker panels
rear deck lid
rear fascia
Interior:
FR500 leather seat trim
FR500 racing-style steering wheel
200 mph speedometer/9000 rpm tach
JBL Traffic Pro CD Audio/CD-ROM; AM & Dual FM tuner
voice-prompt navigation system
Suspension:
cobra irs with some tuning modifications
different spring rates and shock valving
one inch lower drop
front: 14-inch Brembo front rotors with four-piston Brembo calipers.
front: 18 x 9-inch FR500 prototypes with BFGoodrich G-Force T/A KD 265/35ZR18
rear: 13-inch Cobra rear discs with LS single-piston calipers.
rear: 18 x 10-inch FR500 prototype rims, BFGoodrich G-Force T/A KD 295/35ZR18
front MacPherson strut system replaced by bolt-on double A-arm suspension, consisting of rear upper arm from Lincoln LS and fabricated lower arm.
Springs and shocks similar in design to Lincoln LS, but rates and valving unique to FR500.
setup moves front axle 5 inches forward, giving FR500 a wheelbase of 106.3 inches
It's also one of the keys to achieving a 50/50 weight distribution.
more info from fast-autos.net
$54,000
16/23 mpg
Curb Weight: 3587 lbs
6-Speed Manual
Displacement: 4997 cc
415 bhp @ 6800 rpm
365 lb-ft @ 4200 rpm
7000 rpm redline
0-60 mph: 4.5 sec
0-100 mph: 10.9 sec
1/4 Mile: 13.0 sec @ 110 mph
60-0 mph: 119 ft
Skidpad: .94g
Top Speed: 168 mph
Slalom: 66.3 mph
pics:
make it pitch black, and powdercoat them rims, black tail lights and front black/clear lights, and all black interior... ooh yeah :pimp
thats thing is hot. i love that hood.
that front end nods thanks to the fox body, the body lines are sharp and clean, and the power is just insane for a factory produced car. going into production? that is the 04 show i guess with the old body style
I was never one for the fr500 rims, or that bumper.
But that is very nice. I like the numbers! That is what usually matters most to me.
It looks a little bare on the back without at least a factory wing or something though.....
somethins not right wit the body... and its not the hood i think its the rear end lik someone said. other than that. hotttt
Zoolander
Needs more of an aggressive look in my opinion. Great numbers, but the body could be nicer. Too plain for my taste. A stock body is by no comparison than that body style in my opinion.
Discussion Starter #12
saj, you are probably looking for the triple deck 15 foot ricer wing :lmao :lmao :lmao
and the sema pictures are from nov 2 1999 :wink
it seems like it might obstruct airflow with the hood. what i dont get is it is a "heat extractor" v6 hood from 01-04, but the front end is closed up from where heat should go in...
styling is plain, but fast- kind of like luxury ownage (cadillac cts- northstar v8)
my truck will smoke ur **** anyday. wait till i get my next fox :rockon
1 - 20 of 23 Posts
