All of you guys that dont want to spend 150-200 bucks on a short throw shifter here is a mod that is free but actually works... i had to surrender my upr blue thunder shifter and put a stock one back on it... well i got to thinking and i was like man.. that is a lot of rubber
If you will notice right above this at the bottom of the shifter handle is a metal place with rubber all inside it... all you have to do is
1. Get the shifter handle out of that little metal cage and get all the rubber off of it..
2. Get something that will barely fit inside the holes on the shifter. I used a washer that would barely fit but still be tight around the bolt to stop slip..
3. Find 2 shorter bolts that are the same size as stock shifter bolts..
4. Then bolt them back up... This will make a world of difference in how solid the handle is.. I was really surprise how well it shifted after i did that.
