1 - 2 of 2 Posts
My car for the longest time now has had a problem with not wanting to start up and run after it has been driven and then sat for about an hour, its like its either starving for fuel or air not sure which, but when it is cold it fires right up, I have an exhaust leak that will be fixed very soon, driver side of x pipe isn't seating up, could that be affecting my o2's and causing them to tell the comp to dump more fuel because of the leak, could that be leaning out the motor??????
Mine has a hard time with hot starts. Started doing it after the supercharger install and pprv delete. I replaced the front 02's and cleaned the iac and it still does it.
1 - 2 of 2 Posts
