1 - 14 of 14 Posts
So I'm going to swapping out my front suspension for a turbo Kmember from maximum Motorsports and all the stuff to make it work. My question is what spring rate should I get for the front ....... I was thinking 425lb springs since I want a track/street car. Also I have 650lb springs in the back with cobraR shocks.............. Also I willl be doing a 5.4 swap later on in the future
Discussion Starter · #2 ·
Bump
BYAHHHH!
300 is the highest Id go.
also..its not a turbo k memeber its just a k member
Maximum Motorsports sells tubular kmembers for turbo applications and nonturbo
Also I don't care about ride quality. I only care about performance
BYAHHHH!
for the hellion kit?
Yes
BYAHHHH!
is your a drag racing...no higher then a 250 spring tops
Discussion Starter · #11 ·
I meant to say I'm into autocross........ I'm not to sure why I said track lol
BYAHHHH!
oh...idk then
Abyssinian of AX
You'd better care at least a little about ride quality, as you will get the crappola beaten out of you on the street and handling would suck :(
I used to run 300# up front and were not high enough for AX. Ask the MM tech, but seems to me 425 is about as high as you wanna go... unless you wanna get really high, like this dude:
Are you going CO's out back as well? I know that the IRS requires MUCH heavier spring rates, but hopefully teej will chime in. He runs CO's out back on IRS and can give you his thoughts on the rates he runs and how they may do for AX.
Jazzer :)
Discussion Starter · #14 ·
I don't. Drive the car much so I honestly want a set up that I could just take to the track
1 - 14 of 14 Posts
