1 - 8 of 8 Posts
Might get more interest if you tell us why we need it.
I have never seen or heard of one of these. What does it do? Is it a stand alone ECU? Is it a piggy back ECU? What advantage does it give you over a hand held (SCT, Diablo, etc)? Are they still made/supported by Anderson?
Thanks
googled this,super easy
Unlock the Performance Potential of your ECC-IV with Engine Tuning Adjustability Not Available in any Performance "Chip"!
The P.M.S. goes far beyond the capabilities of a performance "chip", offering a broad selection of adjustments and tuning. Now you can take advantage of aftermarket performance components while still using the stock engine control computer! Step up to the P.M.S. and move into tomorrow's world of performance!
comes with global fuel adjustments, which means you can offset the mass air for different sized injectors.
* Air charge temp and Water temp fuel and timing adjustments can now be made from -40 to +250 degrees
* TPS volts are now adjustable: What this means is if you want 1.05 to be idle you put that in. The same with W.O.T. - you tell the PMS what volts.
* NEW! Easier to use controller with adjustments down to 500 rpm increments starting at 2000 rpm
* NEW! for 2004 single data display screens let you monitor spark timing, injector function, oxygen sensor, water temp, air charge temp., mass air voltage and manifold pressure/vacuum
* Start fuel setting, which controls the injector when the starter is turning the motor over. This gets rid of the hard starting with 42 lb. injector or bigger.
* Air Fuel Mixture fully adjustable.
* Idle Mixture and Timing fully adjustable.
* Stand alone turn on is now adjustable: The stand alone is set up to turn on at 3500rpm, which can be adjusted from 2000 rpm to 5600 rpm. The factory EEC has no control in standalone mode. This gives us even better fuel and timing control and now the Rev limiter can be moved to as high as 9900 rpm with a faster processor.
* Total spark and rate-of-advance fully adjustable.
* Two step rev-limiter.
* Two programmable RPM/Throttle output accessory control switches.
* Tunable Nitrous Oxide Adjustment Table.
* Tunable Turbo or Supercharger timing and fuel adjustment up to 30lb of boost.
* Purple anodized, finned aluminum case resists corrosion, dirt and moisture!
* Easy installation in less than one hour.
* Plug in and Run” installations requires no programming—Just start it up and go!
* Increased RAM, EPROM, and EEPROM Internal Memory Capacity!
* Easy “User Friendly” operation—detailed owner’s manual explains all functions.
---------- Post added at 03:33 PM ---------- Previous post was at 03:32 PM ----------
this is the last part i have to sell. make me an offer,i just might take it.
1 - 8 of 8 Posts
