1 - 2 of 2 Posts
I've got bbk fuel rails for sale brand new in open box $175 obo plus ship or pick up
i have a Diablo sport MAFIA mass air flow extender used $150 obo
. a new never installed vortech 8 rib 3.33 super charger pulley $75
i have the engine i pulled out of my car .020 over stock crank rods and pistons runs good no noise uses no oil has approximately 60,000 miles on rebuilt engine only issue is oil pressure little low for my taste when idling hot in gear with factory converter at about 700 rpm it has 20psi was advised new high volume oil pump will fix it it cranks with about 60-70 cold . will take $1600 for entire long block
or $550 for heads with Bullet "CMS stage 1" cams installed if someone wants to do pi swap.
After i get everything on mine and properly spaced i should have full set of 8 rib pulleys but have to wait and see whats left over. will have stock unknown mileage 28 spline differential as well as both stock 28 spline axles back by end of week make reasonable offer on those
the heads, are they romeo or Windsor heads? how many miles on the heads/cams? does it have after market valve springs in it? willing to ship? p.m. me
1 - 2 of 2 Posts
