1 - 2 of 2 Posts
94 gt, 50k. Recently she has become hard to start in the morning. I'm assuming the fuel pressure is bleeding down. On these 5.0's what are the usual suspects?
Check the fuel pressure first before you assume, but slightly gummed injector, fuel pressure regulator, and pump can all cause bleed down. That being said, the system primes when you hit the key, so you may need to check other things as well.
1 - 2 of 2 Posts
