1 - 12 of 12 Posts
hi you can call me mater
Well after talking to my tuner about me going turbo and maybe turbo cammed
He said to get an aviator fuel pump
Well would that be enough to support 6-8psi daily?
Or should I go focus fuel pump, or KBAP?
Or what?
And I found a good deal on 39lbs injectors are those enough?
03cristian
Discussion Starter #2
Also will a walbro 255 drop right in?
03cristian
Anyone?
03cristian
pretty sure the walbro and fucus will Drop right in. No idea about the aviator.
this is a far stretch but isn't the aviator only for return fuel system?
My tuner said the walbro is for return and not ideal for my setup
And that the aviator will drop right in no problem and its rated at 310lph so i'm on the hunt for a cheap one now:(
03cristian
aviator or svt focus pump is what you will want. walbro's are generally return pumps. 39# injectors will be enough for a stock bottom end.
Still enough for ported heads, ported lower and cam?
03cristian
the svt focus and aviator will drop right in
the pump is all you need, the aviator and svt focus basket which is sometimes included with a new pump is not needed
depends on how much boost/power you plan on. focus pump and 39/42 lbers seem to give out at about 400rwhp. the aviator is supposed to be a little better flowing than the focus pump, but dk how much more it would support over the focus, if any.
im going with the svt focus pump and some termi injectors for now
will add a boost a pump or do upgraded wiring if slightly more fuel is needed for now
1 - 12 of 12 Posts
