1 - 20 of 33 Posts
Anyone know where the fuel filter is located ???? any special tool needed????
It is wet out and i cant see getting dirty unless i have to so any help is greatly appreciated!
right underneath the drivers side, has a black cover over it
  • Like
Reactions: ia07gt
Like Catfiesh said, black plastic cover, it's about 6-8" wide and 18-24" long. Held in with a couple of retaining screws, doesn't have to completely come off to replace the filter. Black band around filter doesn't have to come either, just disengage the green clips (things are a bitch with big fingers) slide the filter and try not to kink the fuel lines.
Good luck! :D
Here is a pic of part of it, for some reason I didn't take any of the entire cover. It's literally the only black plastic shroud you can reach from directly under the driver's door.
Thanks any pics???
green button things how do i undo them??
Squeaze. They're pressure clips. Press hard on both sides, it'll unlatch, then slide it out. I never noticed a pop or release, they unlatched quietly. Was cursing too, pressing both fingers really hard and making mean faces far longer than I suppose I had to. :mad: :)
OMG!!!! everyone has gotta see this! I am taking a pick of my fuel that was in the old filter! IT is way dirty!!! and i just got dynoed
Definitely want to see that. I mean, I was making fun of Iowa's fuel before, but photographic evidence would be icing on the... ok, I'll stop being an asshole. :)
How many miles on your car?
Discussion Starter #10
Discussion Starter #11
thats 34k miles 2.5 years and 2 fuel pumps worth of fuel and i only run ethanol.
Golf Pencil Kawk Juggler
Yea thats gross. Stop showing us pictures of your urine samples.
Discussion Starter #13
Not urine just winter blend fuel with other fuels
lol...jk man. hows it smell?
Blech. Glad I didn't look at mine when I swapped it out. Course I also had 9k fewer miles.
Discussion Starter #16
smells almost like whiskey LOL!!
Discussion Starter #19
Yea i think winter blends are to blame on this one plus i had to get gas in chicago 1x and i have minnesota gas in there too. Not to let out the worst gas i ever put in was 91 from st. Louis!!!
Discussion Starter #20
once again a huge thanks to you guys here at Modded Mustang forums
1 - 20 of 33 Posts
