19#So the PINK injectors are 19lb or 30lb ?
no, any power upgrade even N/A will eventually need bigger injectorsand even then the only mods that they help are t/c or s/c right?
I was informed that the pink injectors were 21lbs.
You both were told WRONG.Yep Blackbird is right i was told by a rep of AmericanMuscle.com that pink injectors were 21lbs.
and you would be wrong sir. They are indeed 21lb/hr injectors. The ECU reads them as 19's but they are in fact 21'sYou both were told WRONG.Yellow or Pink are 19# as in all 99-04 GT's.
Here's a quote from Jerry who was with SCT " All GT's have 19's. The pink injectors are 19# injectors. I have no idea where this 21# stuff started from but it's WRONG. Now, the 3.8L's do use a 21# injector since 1999 when they introduced the split port motor."and you would be wrong sir. They are indeed 21lb/hr injectors. The ECU reads them as 19's but they are in fact 21's
