Read much?
Read much?my 99 came with 19#(9f953) but the 01+(romeo) came with 21# which were pink in color I believe. don't remember the color of my 19# but they were not pink
From what I understand there are 21# injectors , but only 19's were used in the GT's . Some are yellow/orange and the later models were pinkish. I have to go with what Jerry says.Jayc here's a site that has flow tested the pinks and they also say they are 21's.
Ford 14# 19# 21# 24# 30# injector service
check it out.
True, Jerry is just the best resource I have.That's fine niether of us have flow numbers so to be 100% sure we'd have to get an orange and pink one and get them flowed.
factory freak :dunnoI have pink injectors on my 03 GT and can anyone explain to me how come when I connect a scanner it says Im running 42lbs of fuel pressure. The car is bone stock with an auto trans. Went to the track and slapped on Toyo Proxes RA1's tires in the rear and ran a 13.9. To my knowledge the car is bone stock, smooth idle, stock heads, stock pullies, stock intake and sotck exhaust. On the highway I cruise at 65mph and the rpms are just above 1500. If I am not mistaken I have 3.27 gears. The car has 53K and on the dyno it reads 258 rwhp and 300 torque.
The car is a complete anomaly if it is a bone stock auto and putting 258/300 to the wheels, they typically put down 220 or less on a DynoJet inertial dynamometer. Did you record AFR during the dyno run? If it was as it should be (12.5 to 13.0:1) then it must at least have a tune as the late '02 through '04 GTs with the pink injectors run PIG rich at high loads and WOT.I have pink injectors on my 03 GT and can anyone explain to me how come when I connect a scanner it says Im running 42lbs of fuel pressure. The car is bone stock with an auto trans. Went to the track and slapped on Toyo Proxes RA1's tires in the rear and ran a 13.9. To my knowledge the car is bone stock, smooth idle, stock heads, stock pullies, stock intake and sotck exhaust. On the highway I cruise at 65mph and the rpms are just above 1500. If I am not mistaken I have 3.27 gears. The car has 53K and on the dyno it reads 258 rwhp and 300 torque.
:withstupid^^^ What he said.![]()
No , it would just lower the duty cycleYes they are pink on my 02 gt and on my friends 98 gt thay are yellow, now would bigger injector like 24lb or 30lb add more power to the engine?
BullHere's a quote from Jerry who was with SCT " All GT's have 19's. The pink injectors are 19# injectors. I have no idea where this 21# stuff started from but it's WRONG. Now, the 3.8L's do use a 21# injector since 1999 when they introduced the split port motor."
There is no better source of information than Jerry, no matter what internet myths are out there.
