1 - 4 of 4 Posts
03 Mustang 3.8 SC
Hey guys just wanted to ask about fuel injectors. So I have a Eaton m90 for my 3.8 and was wondering if I have to upgrade the fuel injectors or can the stock ones hold up?
BoostedGT
I would say with the 22lb injectors your car comes with stock you should upgrade to maybe 30# depending how much power you plan on making.
03 Mustang 3.8 SC
I’ve been told it would make less than 300hp or just close to 300hp. Another question would I have to keep the same style of fuel injectors for the sc or go with the same as the mustang EV6 style fuel injectors?
BoostedGT
I would suggest the 30# then if you think you will be around there. You could keep your EV6 style or swap you could alwasy get an adapter harness if you swapped to a different style.
1 - 4 of 4 Posts
