1 - 6 of 6 Posts
ok well finally looked at the fuel line (last week exhuast burned a hole in it)..and i finally got in there..cuz out the section and i didnt know that the stock fuel lines are high pressure 2 peice hose's..well i was gunna just splice in a piece to connect it..but i dont wanna run the risk of a fuel leak and BOOM...so where can i order this ****?
rubber..is rubber the return?
Message
is ^^^ that what i need..
the rubber lines have the rubber protective hose then a hardend plastic line that the fuel goes through in the middle? right? cuz thats how this is..it wouldnt have leaked with my stock 80lph fuel pump..the 255lph i have doesnt help
You can replace the whole rubber/hardened plastic part with any 5/16 high pressure fuel hose. Just make sure it is high pressure (100 PSI) rated. Then if you are worried about temp or abrasion you can put some heat wrap on the hose or get a hose with a steel braided outer section.
1 - 6 of 6 Posts
