1 - 8 of 8 Posts
Commoner
Just finished a rebuild and when I went to fire it up for the first time, it wouldnt.. The fuel pump is not priming and I dont know why. Tt worked fine before. The inertia switch is reset and fine.
Check the fuel pump fuse. Its under the hood.
Everything was plugged in correctly?
Commoner
Everything was plugged in correctly?[/QUI
I heard its a 20 amp fuse? I cant figure out which one it is. Im pretty sure but I cant say Im 100% positive. The ccrm also makes a clicking sounds for a second when on turn the ignition on
You can download an owner's manual from Ford's site--click here...
Commoner
I figured it out but thanks guys, it was just one of my grounds near battery wasnt quite tight enough..
1 - 8 of 8 Posts
