Anyone with F/I know what ur fuel rail pressure is?
O obdnanr · Registered Joined Nov 25, 2007 · 1,762 Posts Discussion Starter • #1 • Mar 8, 2008 Anyone with F/I know what ur fuel rail pressure is?
Trick Tuners · Premium Member Joined Nov 11, 2006 · 4,464 Posts #2 • Mar 8, 2008 Rail absolute pressure (RAP) is 40psi + boost or - vacuum At 20in hg (=~ -10 psi) its 30. At 10psi boost its 50.
ChrisJ · Administrator Joined Aug 26, 2005 · 76,434 Posts #3 • Mar 8, 2008 Mine idles at about 30... In boost I have seen it hit 60...
I itschristorres8 · Banned Joined Aug 23, 2006 · 15,799 Posts #4 • Mar 8, 2008 generally during cruising and idling fuel pressure should stay as stock is just like your vacuum if not then theres something wrong on the tuners end
tsp_2177 · Registered Joined Mar 23, 2007 · 1,868 Posts #5 • Mar 8, 2008 sorry i have no idea but Chris pm sent :lol
O obdnanr · Registered Joined Nov 25, 2007 · 1,762 Posts Discussion Starter • #6 • Mar 8, 2008 fuel rail pressure right?? cause im wondering it the low fuel pressure rail is why my car seems to lean out when i WOT sometimes
ChrisJ · Administrator Joined Aug 26, 2005 · 76,434 Posts #7 • Mar 9, 2008 Maybe you are running out of fuel pump?
I itschristorres8 · Banned Joined Aug 23, 2006 · 15,799 Posts #8 • Mar 9, 2008 ChrisJ said: Maybe you are running out of fuel pump? Click to expand... with the stock fuel pump i wouldnt doubt it they top out at about 300rwhp i believe
ChrisJ · Administrator Joined Aug 26, 2005 · 76,434 Posts #9 • Mar 9, 2008 itschristorres8 said: with the stock fuel pump i wouldnt doubt it they top out at about 300rwhp i believe Click to expand... if he is on stock pump then that is what I would put my money on...
E ESG-642T · Banned Joined Feb 23, 2007 · 12,740 Posts #10 • Mar 9, 2008 Stock PUMP! Sounds like the culprit.
O obdnanr · Registered Joined Nov 25, 2007 · 1,762 Posts Discussion Starter • #11 • Mar 10, 2008 well when the dude was tuning it my **** was at like 60 psi
