1 - 2 of 2 Posts
Gas gauge on my 96' gt has been stuck on empty, does this mean i need a new sending unit or could it be something else?
sorry this is a month late only discovered this part of the forum...
it may be a bad earth or the sender wire, sending unit in the gas tank, the gauge wire has been cut, corroded or disconnected in some way... see if you can get a multimeter and test the wires and make sure your getting some voltage/Ohm resistance before replacing anything.
1 - 2 of 2 Posts
