1 - 3 of 3 Posts
Sean Daly
Okay so on two occasions now my gas pedal has gotten stuck and I looked it up online and there was a recall because of this in 04. I called Ford and they said there isn't a recall. Who else has had this happen to there 99-04 stang and what did you do??
4POINT6
I read that the dealership either just trims the carpet where it gets stuck or attaches a metal plate after the carpet is cut back. I called ford too, when I saw your post and my vin doesn't bring up any recalls either. As far as I know, it's mainly for the termi's.
Pays in respect
Check the spring that links the cable to the TB. If that's fine, consider raising your pedal with a spacer. Simply buy a nylon spacer that's 3/4" long, slip it over the end of the TB cable inside the car (cut it length wise to accomplish this) then clamp it into place. Your pedal will be higher off the floor and have less slack.
1 - 3 of 3 Posts
