1 - 10 of 10 Posts
Hey all, this might be a silly question, but for H/C/I upgrade, what all gaskets are needed besides the obvious? I have the head gaskets, valve cover gaskets, upper/lower intake gaskets. What am I missing? I've never done this job before, and want to start this weekend. Also, recommendations on where to buy any needed/missing parts. Thanks in advance fellas.
timing cover gasket then you should be good
timing cover gasket. Got it. Thank you Hatch.
which heads you runnin? not many heads run stock spark plugs. Do yourself a favor and drain the coolant before starting it, when you pull the first lower head bolt out youll find yourself in a big ass coolant mess
Im gonna put on a pair of Trick flow twisted wedges, I've also got a cobra upper/lower intake, and a Trick Flow stage one cam. Also MAF/injectors, TB, and the car already has X pipe exhaust. Its a start I guess. :)
Throttlebody and Egr gaskets. Or make them yourself out of a blank sheet of gasket material that you can buy at an autoparts store. Hard to find larger TB gaskets.
I think I have the throttle body gasket, but if not, the autolite 3924 is the matching gasket I take it?
Discussion Starter #10
Thats what happens when I try to think without coffee LOL. Thanks Matt.
1 - 10 of 10 Posts
