Hello,
I have a automatic 2003 Mustang v6 convertible. So, I'm unable to put it from park to drive. I thought it would be the brake light switch so I replaced it but that didn't work. There are two wires that connect to the brake light switch, and one was disconnected so I had it taped onto the switch and there would be a spark. Right before I replaced the switch I wasn't getting any sparks and I still don't now that I replaced it. The brake lights do not come on and yes I installed it properly. I checked the fuses, they seem to be ok. I don't think I need to replace the neutral safety switch because the break lights should come on if that was the case, right? So, not the brake light switch, not fuses, not neutral safety switch, so what could it be? I noticed a white and blue plastic clip that is clipped onto the brake pedal with two wires connected to it. Does that have anything to do with it? Please help me out, Its thanks giving and I have to drive to visit my family. Any ideas would be extremely helpful. Thank you.
