1 - 9 of 9 Posts
Whats up mustang enthusiasts !!! I just have a question about gearing's will a 1992 mustang gt (3.73) fit in a 2002 mustang gt .... The reason I ask is so that I don't have to spend for a ring and pinion and only a gearing installation kit ..Thanks
Parts
Want to build my 2002 mustang gt (2v) . I was thinking of buy the trick flow twisted wedge heads . There's two kinds I think, but don't know which one to get , also what other parts should i up grade when I do get those heads you guys recommend throttle body, mass air flow sensor ,injectors size ,fuel pump clutch and a hand held tuner ......Thank you Josh
They're a good compromise gear for a naturally aspirated car, and the gear of choice for a centrifugal supercharged car.
pretty sure as long as its 8.8 rear itll work
1 - 9 of 9 Posts
