1 - 20 of 32 Posts
ok so i am getting 373s i told dad it was just the ring and pinion he said somethin about a third member ? ..... are these already set up or what? wat do i do and how much to put in gears
Ok is there a kit i can buy any ideas and the speedo gear runs about how much?
All the kits i see on american muscle are for 96 up and they dont have them for my year
i know they are all 8.8s but i mean they have a tuner to calibrate
Doc
it's good if you plan on rebuilding your diff as well.
what you would be looking for is a "master bearing install kit "
Discussion Starter · #12 ·
ok just becasue i know nothing about gears the differential does or does not house the gears
Doc
the rear end is pretty simple on a car.
you basically have:
ring and pinion (gears)
Differential
axles
there are other things but those are the main parts.
Discussion Starter · #15 ·
i looked on there i need the master bearing install kit for sure? if so there is one for 50 that is a install kit with shims, and the other is shim kit with bearings and its 80 wahts the difference?
Doc
the bearings is the difference and YES you need them.
esp on a car as old as yours man.
think of it this way..
$150.00 extra for the kit now or another $500 PLUS another $150 for ANOTHER rear end rebuild when it breaks because the bearings were old.
Discussion Starter · #17 ·
so if i got ford racing 373s from american muscle for 180
Discussion Starter · #18 ·
and the bearing kit thing from brenspeed for 80 thats waht i need and i should be good?
Discussion Starter · #20 ·
i cant find the right speedo gear for an 89 they are all fro post 1990s help me out thanks i really appriciate this
1 - 20 of 32 Posts
