alright so i have a 2002 v6 mustang with the following mods:
4.10 gears,posi-trac differential, dual exhaust, shorty headers, tuner, and drop in filter.
i will have a precision industries stallion torque converter installed for when i go to the track.
the first three gears are no problem and my car flies through them with the mods i have now. once i install the torque converter, it will lock up all the way to the fourth gear. im hoping for mycar to be able to run in the 14's but to do so, i will have to be around 80mph. my car seems to lose power at around 60mph and im afraid that it will fall flat on its face once it hits fourth gear. is there anything that i can do to make more power in this range? ive heard that if i do 1.8 ratio roller rockers, i can reach higher rpm's safely. is this true? and if so could i extend my shift points using the tuner so that the first three gears last longer?
