1 - 3 of 3 Posts
I really hate having to swing my leg under the wheel when I get in . Wife doesn't mind but I do . Especially if making frequent stops . If I get a column from a 5spd car will I have a problem with not having the A/T lock out ? I drove around with an automatic column on my 5spd Jeep for years until a buddy gave me a std column . I just zip tied the column into unlock all the time so I could remove the key w/o any fuss . What would be the result of the std column in an auto car ? You could start/shut the car off in gear ? I have a line on one but he does not know what it came out of . Just that it's an 87-89 Fox with tilt/CC . Do the auto parts swap over .
Discussion Starter · #2 ·
Tilt is in w/o problems.
Techs should always align the rear of the vehicle before aligning the front. If it's not possible to align the rear, like in this case, an inspection for damaged components must be done to get the rear in spec before even looking at the Kodi front.
1 - 3 of 3 Posts
