1 - 20 of 25 Posts
anyone ever relocated a smaller coolant tank, and got rid of the huge plastic one? can i just simply remove the oem and find a smaller one with a longer hose and put it somewhere hidden?
dont see why not although keep in mind your system will have quite a bit less coolant than it should with that small res and you wont be able to use the coolant level sensor and you would need to make sure the cap is rated at the same psi as the oem one since our systems have the cap on the res instead of radiator as most manufacturers
ah. just realized your talking about the mmr relocation kit. they say it can be used with no problems at all even for daily drivers. i say go for it and let me know how it goes
SleeperStang
Just bedazzle it... Look twice as sweet with half the work of replacing it!
SleeperStang
That thing works wonders... But in all seriousness that stock tank is pretty bad looking so I'm sure a new one would clean up under the hood.
Could always get a cover for it. Once I get on my computer i can post a link.
Sent from my DROID RAZR using AutoGuide.Com Free App
Mach1 FTW
1 - 20 of 25 Posts
