1 - 3 of 3 Posts
- PA Super Comp C4 with trans brake and PA Pro Fit SFI bellhousing, (1 month old with only 4 passes on it) - $2000
- Coan 8" maximum performance torque converter stalled around 5800 rpm behind a 700 horsepower small block, (1 month old with only 4 passes on it) - $700
- Trick Flow R-Series CNC ported 225cc heads part number TFS-52400003-CO1. One head has a damaged chamber that needs to be repaired along with an intake and exhaust valve - $1000
- 2" stepped to 2 1/8" headers with Trick Flow R-series flanges and slip fit Dynatech collectors for 9.5 deck small block in a 79-93 Mustang with AJE K-member. (used) - $300
- CHI Commander 4.0 intake with Dominator flange, thermostat housing kit and braided hoses for a 9.5 deck Ford small block. This is the newest CHI intake which is quite a bit taller than the other CHI intakes. This intake uses a remote thermostat housing similar to a Yates style set up. Everything is included. To my knowledge this intake is not yet available in the U.S. (only 4 passes on it) - $600
- Holley 1150 Ultra HP Dominator part #HLY-0-80673 (only 4 passes on it) - $850
- Aerospace Components slightly used vacuum pump and drive kit - $ 300
- CSR small block Ford electric water pump part number 905C (used) - $225
- Comp Cams custom grind solid roller cam for small block Ford 268/276 duration at .050, .705/.673 lift (used) - $175
- Cam Motion custom grind solid roller cam for small block Ford 280/289 duration at .050, .753/.735 lift (only 4 passes on it)- $200
- 2 sets of Comp Cams solid roller lifters for small block Ford - $175 per set
- Trick Flow black wrinkle finish valve covers with oil fill bung and vacuum pump bung (slightly used) - $75
- Fabricated aluminum valve covers for small block Ford (used and need polishing) - $50
- Ford Racing aluminum driveshaft with 1350 u-joint set up for 9" style yoke - $150
- AED polished aluminum adjustable throttle bracket with return spring for Holley Dominator - $50
- Harland Sharp shaft mount rocker arms for SBF Trick Flow R-series head (only 4 passes)- $700
- MSD Pro Billet 351W distributor with bronze gear and locked out mechanical advance (used) - $175
Contact me with any questions
[email protected]
1 - 3 of 3 Posts
