1 - 17 of 17 Posts
Powered by LSx tears
I made this boring video for a couple of reason. Mostly because I got a new gopro and just wanted to try it out. The other reason is because some of the old guys on the vintage mustang forums are still stuck in the old days, saying combos like mine aren't streetable, and they'll be lazy on low end power. Does it look weak on low end power to you? All video was recorded in Mexico.
Here's a rundown. The beginning is obvious. It start in first, and roll into it slowly, giving it maybe 3/4 throttle and feather it a lot.
At 34 seconds, I'm at about a 25-40 roll in 3rd gear, which is my 1:1 gear....the highest gear I have.
At 50 seconds it's about a 5 roll, with lots of throttle feathering.
At 1:10 I start slow and go through all 3 gears without moving much...lol. I've hit them ll and let off by 1:15
1:37 is about a 60 roll in third.
2:05 is the same.
Discussion Starter #2
Oh and wih the crappy tires that are on that thing, it never really quits spinning them, so it never really goes.
And here is the last one. I know they're boring, but I'm just testing out my camera.
For all the carburetor haters that say they're hard to start, check it out. It fires right up every time. At the very beginning, I put it on the transbrake just to show how loose the converter is (it goes to 5000), yet you can see how well it drives, and never has to get even close to its stall speed to be driven (contrary to what some believe).
What can I tell you Craig. If your car didn't sound like such utter ****, and wasn't so gob-smackingly slow, maybe people wouldn't have these misconceptions.
:shiftyeyes
The internet is full of smart people. Growing up on carbureted cars... they were no harder to start than a fuel injected car... unless there was something wrong. Just like if there is something wrong with a fuel injected car, it can be hard to start... and ditto for the stall myths. My 383 Cuda, while not nearly as wild as this, was pretty decent. Ran a 3000 rpm stall converter in it, and it drove perfectly fine in all conditions. Ditto for the 750 double pumper sitting on top of the single plane intake. Started up perfectly every time... I don't know where these rumors, myths, and untruths start on the internet, but it really is amazing the **** people will both write and believe.
I know man....It's funny. As you can see, it's clearly a 5000 stall, and even with its mechanical secondaries, single plain intake, "big cam," "big heads," all that BS, you can tell the car is very tame to drive around.
what is your combo exactly
Discussion Starter #9
Copied and pasted from my garage with some blanks filled in.
ENGINE
408W:10.48:1
F4TE 351 Windsor Roller Block
SCAT 9000 cast crank, 4.00" stroke
4340 Forged Steel I-Beam Connecting Rods with 8740 ARP 7/16 Capscrew Bolts
Probe Industries 2618 Forged Pistons
Clevite77 Main Bearings
Clevite77 Rod Bearings
Clevite77 Camshaft Bearings
Deep Seat Freeze Plugs
Screw In Oil Galley Plugs
Fel Pro 1 Piece Rear Main Seal
ARP Main Studs
SA Gear Billet Timing Chain
Melling Oil Pump M83
Moroso Oil Pump Pick Up
ARP Billet Oil Pumpshaft
Moroso 7qt Oil Pan
ATI SFI balancer
Bullet custom camshaft: .588/.588, 243/[email protected], 109LSA
Twisted Wedge heads: 59cc chambers, 206 cc intake runner, ported by Lynn Morris
Victor Jr intake: ported by Lynn Morris
MSD Pro Billet Distributor
MSD Blaster HVC coil
MSD Digital 6
Firecore50 plug wires
Comp Cams Ultra Gold rockers
Pro-Systems custom 4150 carburetor
Aeromotive fuel pump
Edlebrock Victor series water pump
JW The Wheel flexplate
TRANSMISSION
PA Supercomp C4
Pro Transbrake upgrade
Neal Chance torque converter, 5000 RPM stall
Strange chromoly driveshaft
Spicer 1350 U joints
Strange 1350 Billet Super yokes
POWER ADDER
Edelbrock RPM plate kit - flowed by IS
EXHAUST
Hooker 6208 ceramic coated 1 3/4" X 3" primary headers
Magnaflow 3" X pipe
Hooker Aero Chamber mufflers 3" in/out
It's been [email protected] on motor, and [email protected] on a 71 jet, at 3475 lbs.
1 - 17 of 17 Posts
