1 - 20 of 24 Posts
Well I put some 19lbers back in the car, and a stokc maf. When I crank it, it runs great idles good, makes I think 15 vacuum, and idles around 14.9 to 15.2. Nice throttle response, but after 30 seconds or so it goes really lean vacuum drops down and idles at 400 ish so I kill it. Any clues? I got a cel to check, couldn't imagine why it would throw one but we will see.
what happened to the blower setup
well why are you taking it back to stock if it looks ok
i gotta stay on here more...i keep gettin behind on everybodys projects
Man I haven't even had a minute to check it. I just constantly work. Came into work at 7 am today when I wasn't suppose to until 10. I'm going to hopefully check it after school tomorrow at 5.
I could afford the turbo kit now, but I don't think it's going to happen. Just sold my 42lbers and lightning maf 8( it's really depressing.
Discussion Starter · #16 ·
Cel was just my egr. It was never plugged in before with the strim but what ever. Either way not my idle doesn't drop down after a while of idling. The car smells PIG rich, burns my eyes in the garage with it idling wiht the door wide open. Wide band is flatlined out lean. Plugs are at .44 and fuel pressure is around 37 ish. Is that gap to closed?
And when I reved it to like 1500 it just sat there. Had to shut it off.
Discussion Starter · #18 ·
Nah I went back to normal plugs. I guess I could try to close them. Theres a little vibration at idle which would prob be a small miss from the plugs being so closed. When it was idling kinda nice for a while it was still to lean then it just flat lines out. Should I keep the egr blocked off vacuum wise now?
1 - 20 of 24 Posts
