so tommrow ill prob get the paxton 1200 sl kit. but i have a few questions. this kit dosent come with the aftercooler but can i add it to it. will i see more hp gains if i do add it. my hole engine is stock. the guy is including a gt500 fuel pump and i am also getting the frpp 39lb injectors.
It will probably be a intercooler you'll need, not a aftercooler. Vortech is air/water and uses the aftercooler. Paxton is air/air and uses a intercooler. Unless the previous owner has changed the set up.
Don't forget u will need spark plugs too. That kit with an intercooler would put u at the 450-470 range easily. In it's current form, I'd say 400-430rwhp. That's the kit I want. Unfortunatly, I'd probably be around 470+ on just that kit without the cooler. I need a second job.
HT0 and frpp 39Lb injectors with a tune from brenspeed or someone like that should net you atleast 400rwhp or more. No more than 450rwhp though. What pulley does it come with?
i am not sure what pulleys it comes with. but yea imma get a tune from brenspeed prob
